JP_TFV1 Posted December 13, 2010 Report Posted December 13, 2010 We are getting an output of 78 when there is no load applied. Is there a way to zero out the value? (4-20mA) Thanks
kaare_t Posted December 13, 2010 Report Posted December 13, 2010 If you use the configurator package for analog modules you can make the offset/gain settings directly. If you want to do it programatically then follow the steps in the manual (see attached picture from manual)
JP_TFV1 Posted December 13, 2010 Author Report Posted December 13, 2010 This is actually what we have been trying to get to work. Do you know if there are certain switch settings on the card required for setting the offset?
kaare_t Posted December 13, 2010 Report Posted December 13, 2010 The special instruction "G.OFFGAN" will put the card into offset/gain mode. Alternatively you can use software switch 4 = 1 (see attached picture)
