nguyenthanhcanh Posted December 20, 2010 Report Posted December 20, 2010 Hello, I have setup the network: Local PLC Network #1 (Ethernet): Node 1, Unit 0 (IP address: 192.168.250.1) Network #2 (Controller link): Node 1, Unit 1 Remote PLC: Network #2 (Controller link): 5 PLC (Node 2 to 6, all are unit 1 on each PLC) Computer connect to Local PLC (Network #1) I have tested the network and can connect to each PLC via CX-P. Now I'm making an VB2008 project using Compolet V2.1 Please help me to config the Finsgateway to access all PLCs from computer . Thanks
PdL Posted December 21, 2010 Report Posted December 21, 2010 Good Job! You mind sharing in short how you did this? I am curious!
nguyenthanhcanh Posted December 21, 2010 Author Report Posted December 21, 2010 In Fins, change ETN network to 1 (default 0) --> add remote network 2 with relay network 1, relay node 1 In Compolet, set address 2.2.0 (net 2, node 2), 2.3.0, ...
