I'm trying to bring a Veeder Root TLS 350 device into our iFix SCADA. I'm thinking the best was using a Fieldserver which will convert Veeder Root RS232 to Ethernet /IP. I figure once I get the data to ethernet IP, then I could use the existing IGS driver (Industrial Gateway Server) to bring into Ifix. Has anyone ever tried this or think it will work. The IGS driver only has Rockwell device options (Contrologix 5400, ENI, etc). What would that Fieldserver replicate as far as Rockwell devices.? It seems I could easily read data from a Controller using message commands. But I'd like to try the IGS driver method first. http://www.fieldserver.com/products/drivers/Allen_Bradley_Ethernet-IP.php Thanks Doug
