dugmick Posted March 8, 2011 Report Posted March 8, 2011 Hi all - I am getting an error in a S7-416 CPU when attempting to add a CP443-1 CP card to the hardware configuration. The CPU is 6ES7 416-2XK04-0AB-, firmware has been upgraded to v4.1.1, and CP card is a 6GK7 443-1EX20-0XE0. The CPU started OK after the firmware upgrade, then after adding the CP card to the configuration, save and compile, then download, it will not start. Take the CP out, save and compile, download and the CPU starts OK again. The diagnostic buffer has several entries, but I have not had much luck finding out where to get a better explanation of their meaning. So here I am, at the home of Siemens common sense, hoping that someone has some insight. Below is the contents of the diagnostic buffer, where event 25 is the first one after a startup with the CP card. Apologies in advance for the length of this post. Thanks for any help! ************************************************************************************************************* Diagnostic buffer of module CPU 416-2 DP Order No./ Description Component Version 6ES7 416-2XK04-0AB0 Hardware 2 - - - Firmware V 4.1.1 Boot Loader Firmware expansion V 4.0.1 Rack: 0 Slot: 3 Event 1 of 74: Event ID 16# 530D New startup information in STOP mode Startup prevented by: - Module or submodule assignment not evaluated or evaluation aborted with errors (SDB 1,3,5,2X,9X) - Cold restart or warm restart necessary Startup information: - Time for time stamp at the last backed up power on - Single processor operation Current/last startup type: - Warm restart triggered via MPI Permissibility of certain startup types: - Manual startup not permitted, corrections in parameter assignment, submodule, etc. necessary Last valid operation or setting of automatic startup type at power on: - No startup type/following memory reset Operating mode: STOP (internal) Incoming event 04:13:56.165 AM 01/01/1994 Event 2 of 74: Event ID 16# 49A0 STOP caused by parameter assignment error or unpermissible difference between preset and actual configuration: startup disabled No relevance for user (SDB no.): 3 No relevance for user (Z2): 0000 (Z3): 0000 Previous operating mode: STOP (internal) Requested operating mode: STOP (internal) External error, Incoming event 04:13:52.293 AM 01/01/1994 Event 3 of 74: Event ID 16# 5962 Parameter assignment error preventing startup in address parameters for submodule Parameter: slot Input address: 16382 of the module with parameter assignment errors Error type: illegal parameter coding Operating mode: STOP (internal) External error, Incoming event 04:13:52.293 AM 01/01/1994 Event 4 of 74: Event ID 16# 5962 Parameter assignment error preventing startup in address parameters for submodule Parameter: slot Input address: 16381 of the module with parameter assignment errors Error type: illegal parameter coding Operating mode: STOP (internal) External error, Incoming event 04:13:52.293 AM 01/01/1994 Event 5 of 74: Event ID 16# 5962 Parameter assignment error preventing startup in address parameters for submodule Parameter: subaddress Input address: 16380 of the module with parameter assignment errors Error type: illegal parameter coding Operating mode: STOP (internal) External error, Incoming event 04:13:52.292 AM 01/01/1994 Event 6 of 74: Event ID 16# 530D New startup information in STOP mode Startup prevented by: - Module or submodule assignment not evaluated or evaluation aborted with errors (SDB 1,3,5,2X,9X) - STOP request exists - Cold restart or warm restart necessary Startup information: - Time for time stamp at the last backed up power on - Single processor operation Current/last startup type: - Warm restart triggered via MPI Permissibility of certain startup types: - Manual startup not permitted, corrections in parameter assignment, submodule, etc. necessary Last valid operation or setting of automatic startup type at power on: - No startup type/following memory reset Operating mode: STOP (internal) Incoming event 04:13:52.288 AM 01/01/1994 Event 7 of 74: Event ID 16# 530D New startup information in STOP mode Startup prevented by: Loading user program or internal inconsistency detected (SDBs less than 200 incomplete, superfluous, or incorrect) - Parameter assignment for MPI or DP interfaces not evaluated or inconsistent (SDB1XXX incomplete, superfluous, or incorrect) - Module or submodule assignment not evaluated or evaluation aborted with errors (SDB 1,3,5,2X,9X) - STOP request exists - Cold restart or warm restart necessary Startup information: - Time for time stamp at the last backed up power on - Single processor operation Current/last startup type: - Warm restart triggered via MPI Permissibility of certain startup types: - Manual startup not permitted, corrections in parameter assignment, submodule, etc. necessary Last valid operation or setting of automatic startup type at power on: - No startup type/following memory reset Operating mode: STOP (internal) Incoming event 04:13:46.427 AM 01/01/1994 Event 8 of 74: Event ID 16# 530D New startup information in STOP mode Startup prevented by: - Module or submodule assignment not evaluated or evaluation aborted with errors (SDB 1,3,5,2X,9X) - Cold restart or warm restart necessary Startup information: - Time for time stamp at the last backed up power on - Single processor operation Current/last startup type: - Warm restart triggered via MPI Permissibility of certain startup types: - Manual startup not permitted, corrections in parameter assignment, submodule, etc. necessary Last valid operation or setting of automatic startup type at power on: - No startup type/following memory reset Operating mode: STOP (internal) Incoming event 02:18:29.765 AM 01/01/1994 Event 9 of 74: Event ID 16# 49A0 STOP caused by parameter assignment error or unpermissible difference between preset and actual configuration: startup disabled No relevance for user (SDB no.): 3 No relevance for user (Z2): 0000 (Z3): 0000 Previous operating mode: STOP (internal) Requested operating mode: STOP (internal) External error, Incoming event 02:18:28.118 AM 01/01/1994 Event 10 of 74: Event ID 16# 5962 Parameter assignment error preventing startup in address parameters for submodule Parameter: slot Input address: 16382 of the module with parameter assignment errors Error type: illegal parameter coding Operating mode: STOP (internal) External error, Incoming event 02:18:28.118 AM 01/01/1994 Event 11 of 74: Event ID 16# 5962 Parameter assignment error preventing startup in address parameters for submodule Parameter: slot Input address: 16381 of the module with parameter assignment errors Error type: illegal parameter coding Operating mode: STOP (internal) External error, Incoming event Event 12 of 74: Event ID 16# 5962 Parameter assignment error preventing startup in address parameters for submodule Parameter: subaddress Input address: 16380 of the module with parameter assignment errors Error type: illegal parameter coding Operating mode: STOP (internal) External error, Incoming event Event 13 of 74: Event ID 16# 530D New startup information in STOP mode Startup prevented by: - Module or submodule assignment not evaluated or evaluation aborted with errors (SDB 1,3,5,2X,9X) - STOP request exists - Cold restart or warm restart necessary Startup information: - Time for time stamp at the last backed up power on - Single processor operation Current/last startup type: - Warm restart triggered via MPI Permissibility of certain startup types: - Manual startup not permitted, corrections in parameter assignment, submodule, etc. necessary Last valid operation or setting of automatic startup type at power on: - No startup type/following memory reset Operating mode: STOP (internal) Incoming event Event 14 of 74: Event ID 16# 530D New startup information in STOP mode Startup prevented by: Loading user program or internal inconsistency detected (SDBs less than 200 incomplete, superfluous, or incorrect) - Module or submodule assignment not evaluated or evaluation aborted with errors (SDB 1,3,5,2X,9X) - STOP request exists - Cold restart or warm restart necessary Startup information: - Time for time stamp at the last backed up power on - Single processor operation Current/last startup type: - Warm restart triggered via MPI Permissibility of certain startup types: - Manual startup not permitted, corrections in parameter assignment, submodule, etc. necessary Last valid operation or setting of automatic startup type at power on: - No startup type/following memory reset Operating mode: STOP (internal) Incoming event Event 15 of 74: Event ID 16# 530D New startup information in STOP mode Startup prevented by: - Module or submodule assignment not evaluated or evaluation aborted with errors (SDB 1,3,5,2X,9X) - Cold restart or warm restart necessary Startup information: - Time for time stamp at the last backed up power on - Single processor operation Current/last startup type: - Warm restart triggered via MPI Permissibility of certain startup types: - Manual startup not permitted, corrections in parameter assignment, submodule, etc. necessary Last valid operation or setting of automatic startup type at power on: - No startup type/following memory reset Operating mode: STOP (internal) Incoming event Event 16 of 74: Event ID 16# 49A0 STOP caused by parameter assignment error or unpermissible difference between preset and actual configuration: startup disabled No relevance for user (SDB no.): 3 No relevance for user (Z2): 0000 (Z3): 0000 Previous operating mode: STOP (internal) Requested operating mode: STOP (internal) External error, Incoming event Event 17 of 74: Event ID 16# 5962 Parameter assignment error preventing startup in address parameters for submodule Parameter: slot Input address: 16382 of the module with parameter assignment errors Error type: illegal parameter coding Operating mode: STOP (internal) External error, Incoming event Event 18 of 74: Event ID 16# 5962 Parameter assignment error preventing startup in address parameters for submodule Parameter: slot Input address: 16381 of the module with parameter assignment errors Error type: illegal parameter coding Operating mode: STOP (internal) External error, Incoming event Event 19 of 74: Event ID 16# 5962 Parameter assignment error preventing startup in address parameters for submodule Parameter: subaddress Input address: 16380 of the module with parameter assignment errors Error type: illegal parameter coding Operating mode: STOP (internal) External error, Incoming event Event 20 of 74: Event ID 16# 530D New startup information in STOP mode Startup prevented by: - Module or submodule assignment not evaluated or evaluation aborted with errors (SDB 1,3,5,2X,9X) - STOP request exists - Cold restart or warm restart necessary Startup information: - Time for time stamp at the last backed up power on - Single processor operation Current/last startup type: - Warm restart triggered via MPI Permissibility of certain startup types: - Manual startup not permitted, corrections in parameter assignment, submodule, etc. necessary Last valid operation or setting of automatic startup type at power on: - No startup type/following memory reset Operating mode: STOP (internal) Incoming event Event 21 of 74: Event ID 16# 530D New startup information in STOP mode Startup prevented by: Loading user program or internal inconsistency detected (SDBs less than 200 incomplete, superfluous, or incorrect) - Parameter assignment for MPI or DP interfaces not evaluated or inconsistent (SDB1XXX incomplete, superfluous, or incorrect) - Module or submodule assignment not evaluated or evaluation aborted with errors (SDB 1,3,5,2X,9X) - STOP request exists - Cold restart or warm restart necessary Startup information: - Time for time stamp at the last backed up power on - Single processor operation Current/last startup type: - Warm restart triggered via MPI Permissibility of certain startup types: - Manual startup not permitted, corrections in parameter assignment, submodule, etc. necessary Last valid operation or setting of automatic startup type at power on: - No startup type/following memory reset Operating mode: STOP (internal) Incoming event Event 22 of 74: Event ID 16# 530D New startup information in STOP mode Startup prevented by: Loading user program or internal inconsistency detected (SDBs less than 200 incomplete, superfluous, or incorrect) - Parameter assignment for MPI or DP interfaces not evaluated or inconsistent (SDB1XXX incomplete, superfluous, or incorrect) - STOP request exists - Cold restart or warm restart necessary Startup information: - Time for time stamp at the last backed up power on - Single processor operation Current/last startup type: - Warm restart triggered via MPI Permissibility of certain startup types: - Manual startup not permitted, corrections in parameter assignment, submodule, etc. necessary Last valid operation or setting of automatic startup type at power on: - No startup type/following memory reset Operating mode: STOP (internal) Incoming event Event 23 of 74: Event ID 16# 530D New startup information in STOP mode Startup prevented by: - STOP request exists - Cold restart or warm restart necessary Startup information: - Time for time stamp at the last backed up power on - Single processor operation Current/last startup type: - Warm restart triggered via MPI Permissibility of certain startup types: - Manual warm restart permitted Last valid operation or setting of automatic startup type at power on: - No startup type/following memory reset Operating mode: STOP (internal) Incoming event Event 24 of 74: Event ID 16# 4304 STOP caused by PG stop operation or by SFB 20 "STOP" Previous operating mode: RUN Requested operating mode: STOP (internal) Incoming event Event 25 of 74: Event ID 16# 4302 Mode transition from STARTUP to RUN Startup information: - Time for time stamp at the last backed up power on - Single processor operation Current/last startup type: - Warm restart triggered via MPI Permissibility of certain startup types: - Manual warm restart permitted Last valid operation or setting of automatic startup type at power on: - Warm restart triggered via MPI Previous operating mode: STARTUP (warm restart) Requested operating mode: RUN Incoming event
