Hi, Does anyone use the WRITE CF function of the NS? I have been looking at an application that may require it (if the format can be converted... ), but when trying to use the example above from the manual, it does not even compile, says something about the filename not being correct.. :shrug: Secondly, is there anyway of reading the binary data from the card, and making it legible? Or are we better to look at something else?
Yeah, seems pretty straight forward.... looks like waiting for the one that has successfully used this command... if there is such a person
Works very well. 'READ DATA FROM FLASH CARD. $W39=READCF($W40,10000,$W0,0); 'WRITE DATA TO CF CARD $W39=WRITECF($W40,10000, $W0,0); W0=Filename, W40 first word write W39 gives status feedback. 0 is good. FFFF is not. Yes thats 10,000 words
Could this have to do with the system version or CXD version you are running? Perhaps james_applied can post which versions he is running. Still strange though.
Actually 8.41 is the latest.. check out myomron.com downloads section.
ok, I installed v8.41 today and tried the CF write, but still get the same error. The command is almost identical to the one in the manual, so not quite the same as JamesApplied. I will use his exact example next time to see if that makes a difference. Perhaps James could post what versions he is using...? On a plus, the ladder monitorn seems to work now, it did not with the earlier system version.
Update. The CFWrite now works!! I am thinking it is something to do with the FileName being in the instruction context, as opposed to being in a $W location... This is what worked for me.. Anyway, can continue with further testing....
Hi people from 2011,
I am a PLC programmer from 2019... :nana:
Did you find how to read a file using variables $W for the file name instead of constant string? According the manual should be possible, but I am getting -1 as returning value...
Thanks a lot!
Edited by Ctor
