Mark- Posted March 16, 2011 Report Posted March 16, 2011 Hello, Today we released a new UBS digital I/O board. It uses the USB HID 1.1 interface for communications. List price is $199. The price includes a USB A-B cable and free shipping (in USA). Inputs • Inputs per card: 15, sink type • Input range 18-30 VDC, nominal 24 VDC • Maximum off-state voltage: 2 VDC • On-state current maximum 2.5 mA / point @ 24 VDC • LED indicators to show activated inputs Outputs • Outputs per card: 15, source type • Output range 18-30 VDC, nominal 24 VDC • Maximum on current per channel 100 mA • Resettable fuse triggered at 250 mA on short circuit • LED indicators to show activated outputs General Specifications • Inputs and outputs are optically isolated from CPU/USB • Inputs are electrically isolated from outputs • Screw-terminal connectors used on all inputs and outputs • Accepts 16-26 AWG wire • USB V1.1/2.0 compliant low speed device • USB HID 1.1 compliant • Operating Temperature Range: 0-70° C • Relative humidity: 5 to 90% non-condensing • Power Consumption from USB port: • Minimum 50 mA @ 5 VDC • Maximum 150 mA @ 5 VDC (all LEDs on) • Isolation I/O to logic: 3.75 kVrms optical isolation • Field power supply voltage: 24 VDC nominal • Software support for Mac, Linux, and Windows • Native support in PeakHMI • Each card has a unique address allowing unlimited card count per PC • Size 4.75" x 5.5" • Jumper to disable LEDs • 1 USB cable included with each board Notes: 1) The card registers as a USB high current device. With all LEDs on the device draws approximately 150 mA. Some USB hubs will not allow high current devices to function. Plug the USB cable directly into the computer or use a powered USB hub. 2) Some USB cables do not properly connect the shield of the cable to each end. If this is the case the card may reset when power is applied or not function properly.
Mark- Posted March 31, 2011 Author Report Posted March 31, 2011 (edited) Hello, New: A free license for our relay ladder logic program is now included with each FX-731 purchased. Features of relay ladder logic program MODBUS Serial (RS-232/485) RTU Master (Unlimited connections) Function codes 1, 2, 3, 4, 15 and 16 MODBUS Serial RTU Slave (Unlimited connections) Function codes 1, 2, 3, 4, 5, 6, 15 and 16 MODBUS TCP/IP Master (Unlimited connections) Function codes 1, 2, 3, 4, 15 and 16 MODBUS TCP/IP Slave (Unlimited connections) Function codes 1, 2, 3, 4, 5, 6, 15 and 16 FX-731 Intergration Supports multiple cards Full address space emulation 000001 - 065535 100001 - 165535 300001 - 365535 400001 - 465535 Editor (Offline & Online) Unlimited programs Unlimited networks 64 * 64 network Direct and indirect addressing Runtime monitoring Binary instructions Examine On, Examine Off, Coil, Branch, Positive One-Shot, Negative One-Shot, Latch, Unlatch, Coil Not, Coil Positive One-Shot, Coil Negative One-Shot Timer/Counters Timer On, Timer Off, Timer Retentive, Counter, Load Accumulator,Load Preset, Accumulator Move to Register, Preset Move to Register Math Add, Subtract, Multiple, Divide (Integer, Double Integer, Floating Point) Scaling Comparison Equal To, Not Equal To, Greater Than, Greater Than Equal To, Less Than, Less Than Equal To Limit, Round, Truncate, Square, Square Root Absolute, Odd Average, Ramp, First Order Lag Move/Convert/Select Binary Select, Binary Count Minimum Select, Maximum Select Swap Bytes Rotate Bits Integer Select Integer to Float Fahrenheit to Celsius, Celsius to Fahrenheit Edited March 31, 2011 by Mark-
