There are no FCBs in MicroWin. To copy network(s), select the network(s) first, by clicking on the vertical 'strip' in LAD editor at the left of the network(s) to be copied. Then CTRL+C to copy network(s). Edited by Homer_BL
Hi Homer, Firstly, thank you for your correction What i means is can we capture/ export the ladder diagram from S7-Microwin programmer to be other document format, like pdf?
Simply print to a PDF printer driver. edit: If you dont have a PDF printer driver, then there are both freeware and comercial printer drivers. The comercial ones are quite cheap and a lot better than the free ones. Edited by JesperMP
