My life Posted May 26, 2011 Report Posted May 26, 2011 Hi, I would like to use H2-CTRIO in one of my projects where I would like to control four servo motors with two H2-CTRIO's. I want to give Differential line driver input to the Servo Drives. I am using an Incremental encoder to input pulses to the H2-CTRIO. Can anyone suggest me how to give A,B and Z Differential line Driver Output (5VDC) to the H2-CTRIO? Also how to connect the Servo Drivers to the H2-CTRIO for Differential line Driver Output? Because I haven't seen 5VDC input to the H2-CTRIO? Can H2-CTRIO generate an Output of 500K Pulses ? If any one has suggestions please reply anything that you know as I am using H2-CTRIO for the first time.
rlp122 Posted May 27, 2011 Report Posted May 27, 2011 (edited) Most of what you are asking is in the manual, which is available online for free at Automationdirect.com. Edited May 27, 2011 by rlp122
My life Posted June 1, 2011 Author Report Posted June 1, 2011 Thank you for your reply. As suggested by you I will go through the manual first then i will get back if any doubts.
