denise01 Posted June 14, 2011 Report Posted June 14, 2011 Hi, I need to programme data to send to a NT 2S. The information must contain a reading giving an output average per hour, does ant one know the correct data transfer functions to use for this task. Regards Peter
lostcontrol Posted June 14, 2011 Report Posted June 14, 2011 All depends. What & how is the NT2S connected to? Is it an Omron PLC? If so, then the NT2S can be configured to read data directly from the PLC. Calculating the average output per hour is a bit more work, what is the resolution required?
Walid Elshazly Posted July 10, 2011 Report Posted July 10, 2011 Which Controller you are using , is This PLC ? Or Other Omron Controller ??
