Dear All! As you know, we can connect PC and GOT via Ethernet (by Gateway protocol, FTP protocol,...) with FTP protocol: we can read file from GOT to PC. However, I can not write file from PC to GOT because can't access the directory Or, if you know other method connect to write file from PC to GOT, please help me to do it. Thanks so much.
Thanks KAZAH! This is program that help us to write file from PC to GOT. However, it has some problem: - When I use this program to write image file to GOT. Although, in the software already display image file, but I can not find it in GOT. - Seem, the read/write file from PC to GOT in DOS, but I don't know command to perform it. So, I want to ask: what do I use command to write fie from PC to GOT? Thanks so much.
Excuse me! Pls explain detail for the problem! I think, write file from client to host server via FTP protocol is no need directory name file because, path file of client is folder store cmd.exe ==> check by command: lcd path file of server is folder is running ==> check by command: pwd Thanks so much
I know that on the GOT, to read a file you have to use get followed by the entire pathname and filename. You can't use cd to change directories. I would assume that the PLC is similar.
to read the data use the FTP client FFFTP or other free http://www2.biglobe.ne.jp/~sota/ffftp-e.html .in the presentation all written
thanks so much! Now, I had already read and write the file from PC to CF-Card in GOT1000 So, I have more question> How to display the image file in CF-Card to Screen?
To display a BMP or JPG look at the Fixed Part Display option. It allows a BMP or JPG on the memory card to be displayed as a part on the screen. If your software doesn't have fixed part display, you may need to update, or use bit part display and just use a bit which doesn't change states.
