Does anyone know GX Explorer ? As i know is a software for remote plc programming. Is necessary to install particular card on plc rack, such web server module ? or normally it can be used with cpu direct connection or C24 ? Max
Guest NHThai
Features of GX Explorer: 1-Centralized management of project data on your monitor; 2-Display of network configuration and data; 3-Read/write from/to PLC CPU by performing drag and drop operation to the displayed PLC CPU; 4-Edit and save a project among a list of projects; 5-Perform PLC diagnostics, network diagnostics, CC-Link diagnostics, Ethernet diagnostics or system monitor.
