Semmtexx Posted July 30, 2011 Report Posted July 30, 2011 (edited) Attached is a lead lag situation I am working on. (It's far from perfect I know). What I am stuck on is how to add an additional input and output to the sequence. Basically, I want input 1 to be the lead and cycle through outputs 1, 2 and 3 in that order with every on-off of input 1. Also, I'm trying to get input 2 and input 3 do pretty much the same thing but in this way: if output 1 is in lead: input 2 will turn on output 2 and output 3 will turn on output 3; if output 2 is in lead: input 2 will turn on output 3 and input 3 will turn on output 1; if output 3 is in lead: input 2 will turn on output 1 and input 3 will turn on output 2. Mainly I just need to figure out how to get the first part going (the cycling of three outputs based on the input 1), and I think I can figure out the rest. I don't want a complete answer, just a puch in the right direction. I hope what i'm trying to accomplish is possible with the AL2 in Alpha. Thanks so much in advance for any help!. alernate1.bmp Edited July 30, 2011 by Semmtexx
ace21122112 Posted August 2, 2011 Report Posted August 2, 2011 (edited) whats your email address? I can email you a little program to strobe the outputs Site wont let me post a vls file 1 pulse = off to on 2 timer on dly = 30 x 100ms 3 set 3 zone compares to look at the current time one turns on between 1-10 second 11-20 third 21-30 4 boolens are tied to the outputs to add the additional logic you need Edited August 2, 2011 by ace21122112
