juan_np Posted August 17, 2011 Report Posted August 17, 2011 Hi, I want to make a proyect with a 314C-2DP (314-6CG03-0A0B), but in the library there are two firmware options, V2.0 and V2.6, How can I know what Firmware has my CPU? I purchased an MMC but It hasn't arrived yet. Thank you in advance.
Homer_BL Posted August 20, 2011 Report Posted August 20, 2011 (edited) Open your project using Step7. Connect to PLC. Go Online. Right click on PLC, select 'PLC->Module information'. In 'General' tab, you will se Firmware version. If you do not have a project, then: Open new project iz Step7. Connect to PLC. Menu 'PLC->Display accessible nodes' Then, 'PLC->Upload station to PG' Right click on PLC, select 'PLC->Module information'. In 'General' tab, you will se Firmware version. Best regards! Edited August 20, 2011 by Homer_BL
juan_np Posted August 20, 2011 Author Report Posted August 20, 2011 Thank you very much for your answer. Regards.
