agrosse Posted November 9, 2011 Report Posted November 9, 2011 I am using a PanelView 600 and an L32E Processor. Recently the time has changed due to Daylight Savings Time. My PanelView is now an hour ahead. How would i go about getting this time to sync up with the new time? And also so it does this automatically at the next time change? Quote
Shiner Posted November 9, 2011 Report Posted November 9, 2011 if you power cycle the unit, in the lower left corner during power up you will see a lit block. Touch it to enter parameters mode and under system settings date and time you can enable daylight savings time. Quote
Crossbow Posted November 10, 2011 Report Posted November 10, 2011 Isn't PanelView and L32E Allen Bradley product? This is the Siemens forum... Quote
Shiner Posted November 10, 2011 Report Posted November 10, 2011 I noticed that as well, don't understand how you could miss that......... Quote
