kig_01 Posted November 14, 2011 Report Posted November 14, 2011 can you help me to explain this program Thank you! Regards kurniawan Quote
Crossbow Posted November 14, 2011 Report Posted November 14, 2011 BIN converts a string bit from BCD to binary. So in your example, bits M200 through M207 (2 nibbles, hence the K2) are converted to binary and written into M100-M115 (4 nibbles). DECO takes a series of bits representing a number and converts it to a string with the nth number bit on. The first parameter is supposed to be a register containing a numeric value. The second is the result string of bits starting location, and the third is the number of output bits to write. I have no idea why the first parameter is M100 and not a register like D100, or a series of bits like K4M100. Quote
JRoss Posted November 14, 2011 Report Posted November 14, 2011 Actually, the third parameter is the number of bits in the source to evaluate. So if you have: [DECO D100 M0 K6] It would decode (DECO) the bottom 6 bits of D100 and turn on the nth bit of a series of bits starting at M0. The destination series of bits would be 64 (2^6) bits long (M0-M63). DECO can also use a bit address as the source address, and treats the bit as a header address. In your case, it looks at bits M100-M105 as a number (n), and turns it into a series of 64 bits starting at M0, and turns the nth bit on. So, the full rung takes a BCD number stored in bits M200-M207, and turns on that bit in the series M00-M63. So if your M200 bit pattern is: 0011 0100 Which is BCD for: 3 4 Then the BIN instruction would move that to your M100 bit pattern as: 0000 0000 0010 0010 And the DECO instruction would decode the bottom six bits: 10 0010 Which is decimal for: 34 And turn on the 34th bit in the M0 series (which is bit M33) turning off all the rest of the bits in the series. Now as to WHY it's doing this.... I have no idea! Quote
kig_01 Posted November 15, 2011 Author Report Posted November 15, 2011 (edited) thank you very much for your explanation I think you are expert in programming mitsubishi PLC, I have the project to replace goldsec PLC into modicon PLC.......so i must translate programming language this PLC. goldsec is one of korean PLC but under license by mitsubishi. technical support for golsec PLC is too bad Edited November 15, 2011 by kig_01 Quote
