Guest Kirkamorey Posted June 18, 2004 Report Posted June 18, 2004 I am trying to Move large groups of information from one GE Fanuc 90-70 PLC running Versa Pro to another PLC of the same set up over an ethernet. I have a mixture of integers and discrete points to move and would like some suggestions as to which is the best way to move the Data. Currently MOVE_INT's are being used at the send end and MOVE_BOOL's are being used at the recieve end for discretes and MOVE_INT to MOVE_INT for integers, I am not have problems with the integers although this is not the best way of doing this. The previous programmers have left a complete hodge podge of dross that I need to clean up. Any suggestions please???
Guest Tank Posted June 28, 2004 Report Posted June 28, 2004 Hi Try to send all registers as one or two groups over the ethernet. Where I work we gather all BOOL's, INT's, WORD's and REAL's into one location of a few hundred registers and have a ethernet COM_REQ read the information from the source PLC to the target PLC and then we reverce the process on the other end. Try using the repartition parameter set to 0 if you arn't already doing so (Word 9 of the COM_REQ). Also remeber you can mix types with a MOV_INT i.e %Rxxxxx =>[MOVE_INT] => %Mxxxxxx Note: I have found that to get the best results you need to use a read COM_REQ (2003) and not a write COM_REQ (2004).
