Guest Nipigon Posted June 19, 2004 Report Posted June 19, 2004 Hi guys, I am fairly new in the PLC world. I would like to know how to "copy" I/O words to Memory words. I am using a TSX37-21 with PL7 Micro Software. Also I am connecting an XBT-G6330 to the PLC. In order to transfer information to the XBTG (Screen), I need to transfer my data into memory space. I cant figure out how to do that. I manageg to turn on and off a relay using the screen by linking one of my screen variable to a memory adress ... used the -| |- but with %MW2:X0 ... and then ----| |------()-- to an output ... but this is probably totaly "hack" and I doubt it's the right way. So ... how do I take information like %IW5.2 or %I1.0 or %Q3.0 I have TSX DSZ 32R5 + TSX DES 32R2 + TSX AEZ 802 + TSX DPZ 10D2A Thanks Nip Quote
jcurado Posted June 19, 2004 Report Posted June 19, 2004 Hi Nip I had never use one XBT-G terminal, but use the XBT-F every day, and I hope this one works the same way. I never use one input or output directly in the XBT, there is no way of doing it. You can only read words and tword bits (%mw0 or %mw0:x5). I see the XBT screen variables as if they were real I/Os. When you want to control an output relay with a wired input, you write some logic. that's what one does with a panel operator. When programing, I use this words and bits to comunicate with the XBT. When I need to turn on a motor, I do a rung with the with a bit to turn it on, other to turn it off (controled by thr XBT) and all the safety requirments. Hope this help João Quote
Guest Nipigon Posted June 21, 2004 Report Posted June 21, 2004 Hi Jcurado, what you are telling me I think ... is that the way I did it ... is the only way. So I take a -||- and assign it a %MW5:XO (Which is a memory bit inside the PLC) and the then connect a -()- %Q3.0 to it . Correct ? I have another question then ... How can I take an Analog Value (4-20mA) and control an Indicator located on my XBT-G6330. If I "Click" on the variable in the XBT-G6330, the only choice I have is %MFi.X ... which is a Memory Float (Real). My analog input are %IW5.0 or something like that ... so How would I convert this information in order to "drive" an virtual indicator ? Is there anywhere I can buy a GOOD book on the topic ... I find that the modicon documentation ... "sucks" ... I dont see how somebody new to this world can learn with documentation like that. Thanks for your help Nip Quote
jcurado Posted June 23, 2004 Report Posted June 23, 2004 As I said, I never used a XBT-G. You can use the INT_TO_REAL function to convert the integer to a float. I only use the Modicon documentation that you can find inwww.modicon.com. You can also find a FAQ section there. João Quote
