[KepServer/MSSQL] Copying data from PLC to Data Base.
Hello, I got a task to fill the data base table, with data taken from simulated channel in KEPServerEX. I would be grateful for a kind of example step-by-step showing what I should do to trigger data flow from KepServerEx simulator (Sine function) to MS SQL Server data base. In KepServersEx's hepl file, there is instruction how to configure it for this kind of data flow however it does not help particulary me. Besides it takes into consideration, the use of MS SQL Management Studio but not the EXPRESS version which I use. All in all I did not succeed in my task and would be grateful for mentioned step-by-step help aimed at complete from-scratch-user:) Best Regards, Peter
