Test>connect to PLC. (Diagram not APPEAR) Pls help.
Hello all. I have a problem when I try to TEST>CONNECT TO PLC, the diagram not appear. What should I do? For information, I use CP1E-N20 OMRON. Here I attached the picture. picture below show the diagram that suppose appear. Picture below show that the diagram not appear. This is my problem. Here is my setting. Is it something wrong? Thanks in advance
The settings need to match what the PLC serial port is configured for. Can you post these from your .cxp file? One suspicion is that you are trying Hostlink from the simulator, yet the PLC is configured for NT link to match the NS...? The PLC needs to be configured for hostlink to match the mode you are trying to connect with from the simulator.
  • Like 1
