Lachuu Posted January 3, 2012 Report Posted January 3, 2012 Hi All, I'm starer in HMI. So please help me out in doing this. PLC: CP1E-N20DR HMI: NS10-TV00B-V2 Concept is simple. I need to measure the length of the sheet coil. I got metal detecting sensor. Once I got signal from sensor I will start timer. Formula going to use is Length = Speed x Time ( Speed is Constant) Not using encoder in this project. So please help me in finding solution for PLC and HMI Regards, Lachuu Quote
Grisha Posted January 3, 2012 Report Posted January 3, 2012 Hi Lachuu, First of all i not recognized with this devices but the concept is very simple, most of the HMI panels permit to make on a display of a value a calculation, so on from this point you can write down this simple equation with your constants and variables according to your PLC. Good luck, Best Regards, Greg. Quote
