Sonny Posted January 9, 2012 Report Posted January 9, 2012 Hi, Its my first post here... I recently found myself in the middle of a project where I think a PLC is the best fit for a controller. I have years of experience with microcontrollers and C programming, but I am not sure that I have the time to tackle learning ladder logic. At this point I am leaning toward using a TECO SG2 PLR for an idle managment system. I believe I will be using 6 inputs and 6 outputs to control a chassis engine as well as a generator engine. Where do I find somebody that is willing to write the program? Thanks Sonny Quote
VoltSmith Posted January 14, 2012 Report Posted January 14, 2012 Teco SG2 is a smart relay, not a "proper" PLC. I think you can write its code yourself. However, I can offer the service, if working off-site and over the net is possible in this case. Rahul http://www.voltsmith.com Quote
