Hello I want to exchange data between 2 plc’s using Fixed Buffer Comm via Ethernet( QJ71-E100) but I Want the data format to be real. As far as Iam aware you cannot send real data using BUFSND command. Any suggestion on how I can do this?
The type ins't relevent. You send Dataregisters from 1system Q to another. However you interpret these registers is another matter. You are using two System Q PLC's. Both are the same and therefor interrpret Real Values the same way so you do not have a problem. Edited by Gambit
