Peter S Posted January 17, 2012 Report Posted January 17, 2012 Dear Friend, I'm new in SCADA. In old site we have Telemecanique Modicon TSX Micro plc (TSX3710001) where we need extend with SCADA system & GSM modem (sending SMS with fault). Application - water treatment, max I/O 100, analog input max 8. There're some options for new SCADA (what i got from net). OPTION1: Use PC with touch screen, connection cable (TSXCUSB485 + TSXCRJMD25) or TSXPCX3030 (PLC - PC), Setup PLC to UNI-TELWAY LINK master protocol, Run OPC Factory Server and SCADA software on PC. OPTION2: Use Schneider 10.4 Magelis Touch Screen XBTGT5230, connection cable XBTZ968 (MAGELIS - PLC). ------------------------------------------------------------------- ---- Questions: for Option1. Q1) - May you recommend some low-cost good SCADA for this application? Q2) - What kind GSM modem I need, where I connect and how I setup? for Option2. Q3 - What protocol needs to be setup ? (UNI-TELWAY or modbus RTU)? Q4) - What kind GSM modem I need, where I connect and how setup? Q5) - Is it possible to archive the trend (levels, flow) and show in Magelis touch screen for longer time or this is only HMI for simple task (start, stop, change mode, setup levels, ...) ? Quote
cHud Posted January 20, 2012 Report Posted January 20, 2012 for Option2. Q3 - What protocol needs to be setup ? (UNI-TELWAY or modbus RTU)? Q4) - What kind GSM modem I need, where I connect and how setup? Q5) - Is it possible to archive the trend (levels, flow) and show in Magelis touch screen for longer time or this is only HMI for simple task (start, stop, change mode, setup levels, ...) ? Quote
