Greasy Posted January 26, 2012 Report Posted January 26, 2012 Does the dl06 have support the shift register function an the iboxes ? Thanks in advance! Quote
b_carlton Posted January 26, 2012 Report Posted January 26, 2012 Is that 'and' or 'in'? The DL06 supports the shift register (SR) I don't see an IBox which also implements a shift register function. Quote
Greasy Posted January 27, 2012 Author Report Posted January 27, 2012 I meant shift register and iboxes two different questions sorry i did not word it better thanks for you reply Mr. Carlton you have helped me in the passed with this direct logic stuff an i thank you very much. Quote
rswolff Posted September 8, 2012 Report Posted September 8, 2012 SHFL and SHFR......one is shift left....one is shift right....you can also cheat and simply do it the old fashioned way we did it before recorded time.....a multiply by 2 is a shift left....a divide by 2 is a shift right.....crazy binary math stuff......... bob Quote
