mswiggins Posted January 31, 2012 Report Posted January 31, 2012 We have a couple of old processors using Versapro 2.04 for programming. I hope to update to Cimplicity, but for now they are using VersaPro. The problem is that I can not see the full description of each bit or integer in the ladder logic. The display only shows 1 line of description. This is quite frustrating and makes the ladder logic hard to follow. I found where you can widen the logic display, but not where you can increase the height. Thanks for any hints to see the full description. Marty Quote
RussB Posted January 31, 2012 Report Posted January 31, 2012 Use Ctrl= and Ctrl- to increase the font size. Rt. Click on a LD background and select 'Options' to find the other controls that you want. You would be much better off upgrading to Proficy Machine Edition. :) Quote
mswiggins Posted January 31, 2012 Author Report Posted January 31, 2012 I figured it out... It took a 2nd, 3rd, or maybe 4th look. In the ladder tab click on descriptions in the white box then select full I did not realize you could select each work in the white box. Quote
