sramo3 Posted February 1, 2012 Report Posted February 1, 2012 Hi. Need your help... When I try to download data (make backup) from e1022,terminal make an error. It reboot and i have a transmission error. At the start of downloading,everithing look normal. Data transmits to PC,but when terminal send DRV CONF ,it reboot thenself,and communication shut down. I use E 1022 E Designer 7 CAB 30 After that I try to send new project from PC to terminal,and it works good.. help me,please Quote
djtron Posted February 1, 2012 Report Posted February 1, 2012 What do you mean exactly with "download (make backup) from e1022" ? For downloading a driver from PC to E1022 it is the best, to use a real RS232 with CAB30. USB2Serial adapters sometimes crash. When download starts, you see on the PC a status screen. Does it counts "retries"? Quote
Gambit Posted February 2, 2012 Report Posted February 2, 2012 The latest version for the E1022 is V1.53. Maybe an update of the firmware will solve your problem. Quote
sramo3 Posted February 2, 2012 Author Report Posted February 2, 2012 (edited) Backup means download project files from terminal to Edesigner. I want to make some modifications. When download starts, i can see 0 retries. It downloads all blocks of program (block0.block1.... alarms),then last thing I can see on Status is downloading "expansion ports".On the terminal I see TX Blok.. then TX DRV CON. After that terminal is rebooting thenself.I dont know why... screenshot Edited February 2, 2012 by sramo3 Quote
kaare_t Posted February 2, 2012 Report Posted February 2, 2012 Do you have any expansion cards in the terminal? If so, try to remove them and try again... Quote
djtron Posted February 3, 2012 Report Posted February 3, 2012 I never used the "Receive" function for the E-Series. But it looks to me very much like a problem with the RS232. Do you use an USB2Serial adapter? What settings did you choose for the "Communication Properties". Did you try lower speed, e.g. 38400? Quote
sramo3 Posted February 3, 2012 Author Report Posted February 3, 2012 I do not use usb2serial adapter. I have rs232com port on PC. Yes,I try lower speed..9600baud. Then all speeds.. Quote
Shewy Posted February 10, 2018 Report Posted February 10, 2018 I am trying to take a copy of a programme from an E1012 screen but keep having this exact problem. Have tried 2 laptops and 2 cables. One direct connection and One using a usb to serial converter. Tried various speeds and always the same. Gets to 7% and shows drv conf but then the screen will reboot and download stops Anyone got any idea?? Quote
Ron_S Posted February 11, 2018 Report Posted February 11, 2018 It's upload...or recieve. To get the program out with just e designer Start a new blank project with the same plc and hmi Then transfer / then recieve Quote
ABADADE Posted March 10, 2018 Report Posted March 10, 2018 Hello I have some problem if anyone can help thanks Quote
Carlos Nakabara Posted December 20, 2018 Report Posted December 20, 2018 (edited) Hi, did someone solve this problem? Edited December 20, 2018 by Carlos Nakabara Quote
sbogudzki Posted January 12 Report Posted January 12 I have this same error. Tryed diffrent adapters, rs232 build in pc transmition error on step expansion ports. Quote
