Hi all, I have an old S5-100U. Its status now is STOP (red LED) and the battery low (ORANGE LED) is lit too. This PLC hasn't power ON for 4-5 years which I guess the battery is drained. Under Istack1, I have STOZUS,STOANZ,NEUSTA and under interrupts I have PEU and BAU. On the CPU itself, there is an "empty slot", is that supposed to be an EEPROM module? Do I need it? Or I can clear the fault just by replacing the battery? Currently it is able to communicate with PG2000 with upload/downloads working, but when the power is reset, my PBs are gone. Sorry for the noob questions. Thanks.
Change the battery - Lithium 3.6V The program is held in RAM and the battery is for back up of the RAM. With a dead battery when you power off you will loose the program. The empty slot is for a an EPROM but you do not need it it if the Battery is good. I hope you have a back up of the program? PEU = Expansion module not connected • I/O bus malfunction • Maximum length of shift register exceeded • Module unknown • Module in wrong slot BAU = - Battery is missing or dead and there is no valid program available on the memory submodule STOANZ = PLC in STOP STOZUS = Internal control bit for STOP/RUN change NUSTA = PLC not yet in cycle after Power ON Edited by Moggie
