wizard Posted February 14, 2012 Report Posted February 14, 2012 Thee application is for makeup/breakout pipe threads. I am controlling an hydraulic motor with the help of three hydraulic pumps, one with variable flow and two with fixed flow. I have to maintain the output torque of the hydraulic motor constant. Output torque = Pressure * Flow. The pressure is given by a pressure transducer and the flow is given the three pumps. On makeup, I am starting with the maximum speed of the hydraulic motor (flow is max, therefore all three pumps are working at max.). While I am advancing with the screw, the pressure is raising (it is more harder to screw) and I have to decrease the flow to maintain the output torque constant. Since I have one variable flow pump and two fixed flow pumps, I will decrease the flow of the variable pump and when the flow is at minimum on the variable pump, I will close one of the fixed pumps and put the variable pump on max and so on. I have almost no experience with hydraulic pumps/motors and I am looking for the best control algorithm of the process.
Inntele Posted February 14, 2012 Report Posted February 14, 2012 We can offer help you. However it is possible not through the gratuitous transfer of results of our intellectual work, but through the work under your particular task.
