dmiller Posted February 14, 2012 Report Posted February 14, 2012 hey! I use recipe management in WinCC flexible. There are five carriers to a scale. Depending on the recipe chosen there are different products on the carriers. I have named transporters for carriers 1, carriers 2, and so on. I want to write out in plain text in WinCC the product name to be loaded into the respective carriers . Is it possible to fix in the recipe handler or do I have to add it on the side? Thanks in advance!
Rowan Finch Posted February 14, 2012 Report Posted February 14, 2012 If I understand your question correctly, the only way to have a fixed text lookup is to incorporate a text list into the data record entry. Then a number can correspond to a text entry that can either be displayed in the recipe control itself or if needed elsewhere via a tag and seperate text list object.
