shoaibmoin Posted February 27, 2012 Report Posted February 27, 2012 Hi all, i have CJ1M and cognex 4g7 vision system (sensing camera) and the product guide of 4G7 vision camera says it can communicate with PLC in 2ways- ETHERNET/IP with AOP and profinet. the vision system has got ethernet cable. i am confused either to buy ETN21 or EIP21. Thanks for any help
PdL Posted February 27, 2012 Report Posted February 27, 2012 CJ1W-ETN21 does NOT support Ethernet I/P or Profinet CJ1W-EIP21 supports Ethernet I/P CJ1W-PNT21 is a Profibus IO Controller unit for CJ series. There is no unit that does both Ethernet I/P and Profinet.
gtsuport Posted February 27, 2012 Report Posted February 27, 2012 One other thing to verify. Make sure that Cognex can supply an eds file for the unit you are using. Omron E/IP requires (as per the specification) that you have an eds file for the device. Some manufacturers don't follow the specs. Hope this will help.
shoaibmoin Posted February 27, 2012 Author Report Posted February 27, 2012 Thank you all for your replies...
