I am trying to connect my pc with an L02 serie CPU using MX Component ver. 3.12 And I cannot locate the L serie CPU in the menu, I just bought this program but I cannot connect. Any advice? Guy
How are you going to communicate with the L? Ethernet? Serial? I don't think that L is implemented directly into version 3.12. Not sure if there even is a version yet that supports direct connection to L. You should check with your local distributor.
You can use the QnUDE setup just fine. Same communications. And 3.15 is the latest release. If you contact tech support they should be able to upgrade you if you just purchased it.
