I'm changing pc's and have several 984's on a modbus plus network that I have to connect to using a Wonderware app. I have the USB module listed in the title and need to use it to connect to the mb+ network. Has anyone done this? I have tried a few searches and had no luck so far. What I need to know is which Ww I/O server or DAserver to use. Thanks for any help
Hello, The TOP Server Modbus Suite (http://www.toolboxopc.com/html/modbusrtumaster.html) supports this specific device that you plan to use (http://www.toolboxopc.com/html/mbsupporteddevices.html) TOP Server is an Invensys Wonderware certified product, so it will work/play well with your Wonderware software applications. An application note on how to setup and configure the adapter connection is available at http://www.softwaretoolbox.com/quickfaq.asp?faqid=2832. They have a trial version available (http://www.toolboxopc.com/html/free_trial.asp) that you can download and test and free phone/email support. I hope this helps you in your quest for connectivity. John
