Hi, I'm trying to code the "Time Action" function ("Time Switch" in the F900GOT, "Time Clock" to the rest of us...). The manual says the data is BCD, but when I set the time values with GT Designer, it seems it's kind of bastard hex. I've set the times in GT Designer to 9:10:11 When I look at the register values, I get, in hex, 09:10:11 (note, not 09,0A,0B) So, here's what's happening: Hex Dec Bin 09 09 0000 1001 10 16 0001 0000 11 17 0001 0001 Has anyone seen this before? Is there an easy way to deal with it? Thanks! Edited by larry818
BCD is nothing more than hex that only goes 0-9. If you had a thumbwheel input, it uses 4 inputs per digit. It can only go 0 to 9. To make 10, you need 2 digits. 9 is 1001 10 is 0001 0000 There's nothing packed about it, simply look at it in hex and it will display properly.
