klauricella Posted April 7, 2012 Report Posted April 7, 2012 I have a MR-J3 servo that I am trying to change the acc/dec. I realize that I have to set the parameters but I am a little confused on what the code number needs to be. It shows an example of how to change the jog speed in the manual. The code number is 820CH I figure the C is hex for PC12 but where does the 8200 come from. Thanks Kevin Quote
Crossbow Posted April 7, 2012 Report Posted April 7, 2012 Did you look at the manual? Section 3.5.4 (1) shows a list of the write codes. Quote
