ETR Automazione srl Posted April 13, 2012 Report Posted April 13, 2012 Explain better : in Italy, Mitsubishi offer has his "GOT HMI" and Bejers HMI with name E1000. In an application with E1070 HMI, i need to collect data from two HMI to a PC. Bejers has ad hoc a software "Beijer Electronics Data Collector" - http://www.beijerelectronics.com/web/beijer_electronics.nsf/AllDocuments/60ECF928C68FDA13C12570BC005A666B - . But this software it's able to work with this panel ? Best regards. Quote
kaare_t Posted April 13, 2012 Report Posted April 13, 2012 I'm pretty sure it works for your panel, however it would be a much better solution to collect data directly from the PLC. The panel is not designed to be a gateway between the PC and the PLC... Quote
