mdu Posted April 25, 2012 Report Posted April 25, 2012 Hello guys Its my first time on this site. I have a existing Siemens 315-2 dp PLC connected to a TP177 HMI and other Expansion modules (analog,digital IOs). There is no profibus master(dp) in the hardware configuration. i want to reconfigure the hardware the PLC i.e. add CP343-1 assign an ip address to it and connect a slave to the PLC. How can i do this without changing the PLC code. Should i delete the CPU in the hardware configuration and insert it again. Thanks
Joe E. Posted April 25, 2012 Report Posted April 25, 2012 What kind of slave are you using? If you have a free slot in the PLC rack, the 343 should just drop in in your hardware config.
mdu Posted April 26, 2012 Author Report Posted April 26, 2012 The Prosonic FMU95 module (from Endress and Hauser) is a new slave and i want to set the PLC 315-2 DP as a master, add a CP 343-1 and assign an IP address to it without making changes to other slaves that are currently connected to the PLC.
Joe E. Posted April 26, 2012 Report Posted April 26, 2012 I think you should be able to add the module without affecting other slaves. I've never dealt with this particular setup, though. Hopefully an expert will chime in soon...
