İmportant subject.How can I use latch (permanent) counter in GX Works 2?
Hi guys.I have a problem.I want to use latch counter in my project but I don't know how i will do it.Could you help me this issue?I have been using GX Works 2 as the progam.
It depends on the type of PLC you are using. If it is a Q (or an L I believe), series you will need to go into the PLC parameters and you can assign which counters you would like to be retentative. If you are using an FX series there are certain counters that are already configured to be retentative. You can find this in the FX series programming manual under devices in detail. Hope this helps. -Dave
