Tank_Harvey Posted June 1, 2012 Report Posted June 1, 2012 Hi I am putting together a PLC project using Proficy - PLC (V7.0 Sim 9) I have decided to use UDT's for my drive memory structure. After nesting some UDT's I have found the validation, opening, closing and downloading times have started to get noticeably longer (over 1 minute) Just wonder if any body has found the same and if anything can be done to reduced the compile time? Have I missed a property switch somewhere? Regards Quote
