PLC70 Posted June 4, 2012 Report Posted June 4, 2012 Hi friends, I want to know programming cables types which could be used to connect S7-300/400 PLC to PC or PG. Please tell me Manual/document which can provide this information.
Rodney Posted June 5, 2012 Report Posted June 5, 2012 Hi PLC70 For PC connection you require a MPI device and for the PG connection the PG has a built in MPI port so it should have a cable for the connection. Rodney
slcman Posted June 27, 2012 Report Posted June 27, 2012 Ethernet, if available will be the best choice ever. However you can use PC adapter from your local siemens distributor. http://cache.automation.siemens.com/dnl/jA/jA1NTkwNwAA_16983464_HB/PC_Adapter_USB_e.pdf Also you'll find a cheaper one at http://www.ind-concepts.com/Siemens_PLC_Programming_Cables.htm seller offer a good support and all cable I bought work fine.
