karisma Posted June 14, 2012 Report Posted June 14, 2012 (edited) Hi all, Anyone knows how to set the parameter of Mitsubishi MR-J2S-10A from MR Configurator? I already have setup161. What the parameters I have to set on MR Configurator and MR-J2S-10A to make connect each other? I use RS-232C as communication cable. Please help..thank you.. Edited June 14, 2012 by karisma Quote
Crossbow Posted June 14, 2012 Report Posted June 14, 2012 The defaults in the software should match the defaults in the drive. Use the MR-CPCATCBL3M cable and it should connect. Quote
