andreik Posted June 15, 2012 Report Posted June 15, 2012 (edited) Good day, I have a Mitsubishi HMI (GT1020-LBL, RS-422 connection interface). I'm going to use an Omron PLC. Is it possible to communicate? Or any manual how to communicate this HMI to other brands? Thanks. Sincerely, Andrei K. GT10UsersMamual.pdf Edited June 15, 2012 by andreik Quote
andreik Posted June 15, 2012 Author Report Posted June 15, 2012 Good day KAZAH, Google can't find "sh80869engl". Thanks. Quote
KAZAH Posted June 15, 2012 Report Posted June 15, 2012 https://rapidshare.com/files/1947072951/SH_NA_080869ENG-L.PDF Quote
andreik Posted June 15, 2012 Author Report Posted June 15, 2012 Good day, "RapidPro is necessary to start multiple downloads simultaneously." message is prompted when I clicked to download the file. Thanks. Quote
KAZAH Posted June 15, 2012 Report Posted June 15, 2012 everything is fine with the file. I checked Quote
plcdp Posted June 15, 2012 Report Posted June 15, 2012 Go to Mitsubishi's website and under downloads choose manuals and enter the manual number SH-080869ENG. This is the GOT1000 connection manual for non- mitsubishi products. Connections to Keyence are documented in there. Hope this helps, -Dave Quote
andreik Posted June 18, 2012 Author Report Posted June 18, 2012 Thank you all for the response. I was able to download the document. Quote
Crossbow Posted June 19, 2012 Report Posted June 19, 2012 My recommendation is not include the SH-, as the US docs are SH(NA). Just put in the numeric portion and you should find it fine. Quote
