I had link a GOT GT1675 with CC-link to a PLC Q02HCPU, i what to know if i can access the PLC program through CC-link network just like Qbus in the GX developer PLC side I/F i can select it to link to Qbus. i have select the GX developer to cc-link but still unable to access it.\ Thank you! Regards sttchui
my current version gx developer 8.94Y i can see only 3 selection for linking PLC 1) Qbus 2) Transparent 3) Ethernet which version does the cc-link can upload & online monitor for GC developer?? Thank you! Regards sttchui
Sorry but I know transparent mode doesn't do it. You can only do transparent mode over serial, bus, or Ethernet. It is possible to program the master PLC if you plug into a serial device on the CC-Link network, such as the AJ65BT-R2N.
