Mitsumi Posted June 29, 2012 Report Posted June 29, 2012 What is the "Data regsiter: system variable register range and overlap" errror? Especially, "ENABLE C/L KEY range " What does it mean? Quote
kaare_t Posted June 30, 2012 Report Posted June 30, 2012 Where/when do you get this error? Screenshot? Quote
Crossbow Posted July 1, 2012 Report Posted July 1, 2012 Without telling us more than the message we can't help. Which software package? When do you get the message? My guess would be GX IEC Developer, and you have used an address in your program which is reserved for the compiler. But that's not what the error reads for that in GX Works2. Basically what it means is that you hard coded an address reserved for the compiler. I know how to change it in GX Works2, but as I said, that error message doesn't look like GX Works2 to me. Quote
Mitsumi Posted July 3, 2012 Author Report Posted July 3, 2012 Sorry, I am using gx-iec develeoper. Quote
kaare_t Posted July 3, 2012 Report Posted July 3, 2012 Screenshot? When does it appear? Other issues? Quote
