Hi. i'm a beginner with Cicode Scada. i'm trying to send some (non-protocol) data via Com1 on my PC to a Device . i wrote a code in Cicode to open a Port i define in Port database named Port1_Bord1 but every time i run my project all ports automatically will be opened and ComOpen function always return -1 value; FUNCTION OpenPort() INT hPort; STRING sPort; STRING Send; sPort = "PORT1_BOARD1" hPort = ComOpen (sPort,1); mmes = hPort; IF hPort >= 0 THEN Send = "somedata"; SendLength = StrLength(Send); ComWrite(hPort,Send,SendLength,2); ELSE Prompt("Not Open"); Message ("Info","Port NOT Opend.", 0); END END I will appreciate your helps.
A few things to check. For an onboard com port1 your Boards and ports form should look similar to the attached screen shot. Ensure there are no IO/Devices using this Port. Also the port can only be opened once. If the port is open and you try to re-open it it will return -1.
Hi chelton. i checked the Board and Port data. they are almost the same as you said. but when i run my project all ports are open with out any command. do you know what should i do?
no i create a new single project. there is no any other program or software using this port. i remove all IO devices but ports will be open when i run the project.
I would suggest you contact Citect global support with your issue, provided the product is in support. You can zip the project and send it to them. ww.citect.com
