Royal911 Posted August 5, 2012 Report Posted August 5, 2012 Hello, I want to know if in the CX-Supervisor 3.1 is a possibility of starting the Trend Graph from a bit and stop it by a bit I need to restart the graph after a change of o project so the trend is start from begging Thank You Quote
tashinz Posted August 6, 2012 Report Posted August 6, 2012 you can use the desired bit as trigger for on condition script (on a project level). in a script use ClearLogFile, StartLogging and StopLogging commands for what you wanna do. regards Quote
Royal911 Posted August 6, 2012 Author Report Posted August 6, 2012 Ok! Thank You for that info! Only that i need not the graph trend that is setup in Loggin , and is viewed with Data Log Viewer! The Trend Graph that i refer is the one that is live on the application , the one that i inserted in the Page! - If u know what i mean - if not i will make a screen print! Thank You Quote
Berti Baker Posted August 13, 2012 Report Posted August 13, 2012 Hi, Isn't the Trend object graph always empty when you restart the Runtime anyway? Regards, BB Quote
Royal911 Posted September 6, 2012 Author Report Posted September 6, 2012 Yes is it! The Trend graph is start empty on the start of the runtime Quote
banker Posted September 19, 2012 Report Posted September 19, 2012 Hi Try to look in the script manual W09E-EN-O1.Pdf. Page 148. Perhaps you can get it to work even that the command is obsolete. Banker Quote
Royal911 Posted September 22, 2012 Author Report Posted September 22, 2012 Thank You! That's it! They are obsolete! But they can be use! I can use ClearGraph , StartGraph , StopGraph ! Have a nice day! Quote
