Labrams Posted August 14, 2012 Report Posted August 14, 2012 We are having problems with our comments in our programs not displaying correctly. When you look at them they are a bunch of random characters. We are using Melsoft GX Developer version 8.8T. We have Q series PLC's that we are reading from. The machines came from Japan so I am wondering if it just isn't reading it correctly and we need another font pack? It came with a printed copy of the program with comments in english so I know they are there just trying to figure out why it doesn't display correctly in the program. Any help is greatly appreciated. Quote
Crossbow Posted August 15, 2012 Report Posted August 15, 2012 The issue is the comments were written in Japanese. Japanese characters take 2 bytes to store. The English version of software uses only one byte character codes (typical of English). So it's taking one Japanese character code and displaying 2 English characters, basically garbage. There is NO way to see the Japanese in the English GX Developer. You didn't give a valid version number either. Your only choice is to use GX Works2 which replaces GX Developer. It has language support and can show the Japanese text so that you can copy and paste it to like Google or another website to translate it. And just because your printout showed English characters doesn't mean that's what got loaded to the PLC. Comments are not used by the PLC, just stored. So it's possible to have a different comment file. Quote
Labrams Posted August 15, 2012 Author Report Posted August 15, 2012 When I talked to my maintenance engineer he said that when they were using the A series PLC's from Mitsubishi they would go in and change from use comments for all programs to only this program or something of that nature. Then the comments would show up correctly but now we are using Q series on most machines and this same tactic does not work. So you don't think it is something to do with the fonts that are loaded? We aren't trying to load the japanese comments but the English comments, but you said that they are different files so perhaps there is a different comment file that we need to find.. Quote
Crossbow Posted August 17, 2012 Report Posted August 17, 2012 The trick with A Series was that you could create 2 comment files, local and global. Still can with GX Developer. SO in some cases, programmers wrote comments in the global list in one language and the local comments in a different language. But this meant the programmer wrote them twice, and saved them twice. And A Series could not store comments, so they had to be in the original project files on the PC. In Tools, under Options, you can check global or local for comments and see if they are there. But 99% chance they are not. Quote
Jaco Posted December 5, 2017 Report Posted December 5, 2017 To whom it may concern, Is there anyone that have a copy of gx developer 8.86Q (Chinese) that can open a project and paste the Comments/tags into an excel spread-sheet and return? Quote
