Hi, I am new to Omron i want to compare equality of two DINT arrays and store the Mismatch Location into an DINT array Please help me out in resolving this logic.. Ex: Source array-DINT to compare with Reference array-DINT and store the Mismatch location of these two array in a Result array-DINT. Please refer the attach file for the more detail
Have you looked at OR, XOR functions etc? They may give you what you require.
You will have to have a look yourself and try it in the simulator. I am just about to go to a plane for work and not sure when back - could be a day or 2 or a week - I do not know.
As you want to locate multiple Mis-match locations, the best way would be with a For-Next loop... Example attached, this is for an Int array, but easy enough to change to DINT, LINT etc Equality Check.cxp Edited by lostcontrol
