Guest Guest_Jeff Posted July 20, 2004 Report Posted July 20, 2004 Hi. Can any one provide the F2 F670 function code information? Need it to understand a ladder program of F2-60MR. Thanks Quote
maccxim Posted August 6, 2004 Report Posted August 6, 2004 F2 F670 instruction is a master instruction that provides a lot of functionality depending from other values and instructions F671,F672 With the combination of these three instruction F670 Kxxx, F671 Kyyy, F672 Knnn you can utilize a lot of special function such MOV,BCD,COMPARE,CONVERSION,ecc... Unfortunately i do not have a .pdf file to send to you by mail. I suggest you to ask Mitsubishi to find an old manual of F2 plc. bye Max Quote
