COMMUNICATION ERROR CC-LINK , MODULE A1SJ61BT11 WITH NA-9131
I take it the NA-9131 is a crevis CCLink station. First we need to know at which baudrate you wan't to set the network. 10M ??? Second the Crevis station is a device station but can be set to automatic(according to number of slices) or fixed to 4 stations. When we know which setting you which to use we can help you set up the master.
Your Switch settings are correct Make sure you've powered down the crevis station and reset de CPU after you make any changes to a switch setting. Give me a few minutes to check your program
You've set your crevis station to mode 0 which means it will always occupy 4 station in the CClink network. Change this to 5 OR change the the line of code at step 46 to MOV H1401 D4
I'm sorry I don't understand your question. I've you have changed your mode to 5. The number of station used will depend on the amount of IO slices used behind the master. The maixmum nr. of stations used by one crevis module is 4. When it is full you will need to start with a new CC-link headstation with station nr 5.
Fortunately we sell system Q and Crevis. I've just tested your program. It's Fine!!! Must be your wiring!!! A-A B-B SG-SG Edited by Gambit
Dear all, I am Vietnamese, My name's Toan. I have a Mitsubishi HMI F940GOT. I uploaded the program from HMI 2 times, it's ok. But I changed and downloaded the program, I got the messege: "Communication error occurred - Receive error 0263" I set PC-"COM1". HMI - "COM1". Baudrate "9600". Can you give me some advises. Thank you very much. Error 0263.bmp
hi Grambit ! please check my picture and program. how to cofigure the system http://www.mediafire.com/?d8l1z67n2uessi5 Why the first NA-9131 RUN, second NA-9131 not run. thanks you very much
Hello,My name is Tinh.I come from Viet Nam.I have a question.How to add file GSD into Codesys.I am using NA 9379. Sorry for my English http://tinhcrevis.blogspot.com/2015/11/blog-post.html
I use program codesys v3.5 patch 1 and I want to connect NA9379 with Profibus Dp Na9122.But It have file GSD i do not add in to the libary of codesys.I have picture Thank all and help me! http://tinhcrevis.blogspot.com/2015/11/blog-post.html Edited by NguyenTinh
