Mitsubishi PLC to PLC Connection using ethernet Module.,HELP
I need to network two plc's using QJ71E71-100.please help me on hardware and programming samples. i need guidance for ethernet parameter, and the instructions to use in data send and recieve,. i've tried using GP.SREAD/GP.SWRITE, but encountered errors ,thankz guys Block Drawing.pdf
@KASAH-i've been using Both GX Developer and GX Works2 @Gambit-any procedure can do sir, as long as i can make the 2 PLC's exchange data. Thankz guys.,.
Did you set up the E71 modules on the same network number? Did you assign the E71 modules with two different station numbers? Did you set up a sequence that corresponds with the manual?
